savvi 0 Report post Posted June 25, 2009 will the sump in a 735i m30 fit into a e30 or do i need a e34 535 sump and is there other dramas with this motor going into an e30 as its from a 7 series cheers shane Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted June 25, 2009 You need the E34 sump. Plus make up a driveshaft, engine mounts (or buy expensive aftermarket ones), And an exhaust. Have a search, There's lots of info about it. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted June 25, 2009 I found this site the most helpful in my search: http://www.e30.de/335i/00.htm Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 25, 2009 You need the E34 sump and oil pick up. I have all the bits and profiled cut brackets for the engine mounts. Plus all the info for this type of conversion... I was doing one last year and cancelled the project because of other comitments Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted June 25, 2009 (edited) e34 535i and e32 735i use the same sump. and yes that will fit your e30. e23 735i , e28 535i and e24 635csi use a larger sump and will hit the cross member Edited June 25, 2009 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted June 25, 2009 FULL RIGHT UP PLEASE! Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted June 25, 2009 Check Forrests link & http://www.jaredsquires.com/ndp/335i/m30/ Quote Share this post Link to post Share on other sites
