jochen 4 Report post Posted June 29, 2009 (edited) NavCoder can now program the followig Daytime Running Lights options on BMWs: ECE-DRL (lowbeam, plus parking- (side)-lights/taillights), standard in Europe DRL-Lowbeam only (no taillights) DRL-Dimmed-Highbeam (no tailights). You can set the brightness value from 0 to 50% A lot of people with Xenons wish to switch off ECE-DRL and change to dimmed highbeams, so as to preserve the life of the very expensive Xenon bulbs. Now with NavCoder, you can do this. DRL is also now legally required in some Euro countries as it is a big safety improvement. DRL simply means: you don't have to remember to turn your headlights on during the day, the car does it all the time. And then turns the headlights off when you turn the key off. Valid for any BMW with LCM from coding index 18 to 30 - which means E38, E39, X5 (E53) from around Sept 1998 onwards E46 pre-facelift X3 and Z4 - not sure, you'd need to check the LCM CI version Edited June 29, 2009 by jochen Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted June 29, 2009 Great work Jochen. How does the 'dimmed highbeam' function work? Run halogen highs at a lower wattage? Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted June 29, 2009 Nice work Jochen - I for one am keen to give this a crack. I was considering getting some LED aftermarket DRL's, but this is a much nicer (and cheaper) solution. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 29, 2009 (edited) Great work Jochen. How does the 'dimmed highbeam' function work? Run halogen highs at a lower wattage? The dimmer uses PWM (pulse width modulation) to vary the duty cycle. This in turn reduces the average voltage and thus reduces the light output The amount of power used also reduces Edited June 29, 2009 by jochen Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted June 29, 2009 Will give this a crack tonight and report back thanks Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 29, 2009 Sounds cool... would be nice if i could have my lights on all the time at the turn of a key however. (allways use park+foglight) Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 30, 2009 Sounds cool... would be nice if i could have my lights on all the time at the turn of a key however. (allways use park+foglight) That's exactly what DRL is. Choose DRL-ECE otion and lowbeam+taillights are always on when the car is on. Note: you're not allowed to have foglights on all the time, this is in conflict with the traffic regulations. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 30, 2009 Will give this a crack tonight and report back thanks Hi Josh - don't code if you have LCM coding index 31 or higher. Let me know what you have. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 30, 2009 That's exactly what DRL is. Choose DRL-ECE otion and lowbeam+taillights are always on when the car is on. Note: you're not allowed to have foglights on all the time, this is in conflict with the traffic regulations. Hmm, I would set this, but my car is much too old for that I diddn't know that it was illegal to have your fogs on all the time... Seems a bit silly imo... Unless they were giant foglights like 4WD's have. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted July 2, 2009 I diddn't know that it was illegal to have your fogs on all the time... Seems a bit silly imo... Unless they were giant foglights like 4WD's have. Most countries have folglight laws that translate to "use foglights when it is foggy" ie: when not, don't use them The size of the light (giant 4WD, mini Twingo) makes no difference The rear fog light is the especially dangerous one - can be blinding for the following drivers LTSA says: Fog lamps should be used when visibility is severely reduced – eg by snow or thick fog. They give out a short, wide beam of light that shines underneath the fog, lighting up the foreground and helping the driver see the sides of the road better. Don't use fog lamps when the weather is clear, as you could dazzle other drivers. Rear fog lamps make the back of the vehicle more visible in fog. They are very bright and likely to dazzle drivers behind you, so they should also only be used in foggy conditions. Personally I think they have the "dazzle other drivers" part with front fog lamps wrong. Then, in their other doc, they state: "On the road Fog lamps should only be used when visibility is severely reduced, eg by snow or fog. It is against the law to use fog lamps in clear conditions (day or night) as they can dazzle other road users." There you go. Permanently on front fog lamps are not allowed in NZ. Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted July 2, 2009 Mine are "Driving lights" not "Fog lights" Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted July 3, 2009 Mine are "Driving lights" not "Fog lights" ohhh - that's even worse. They'd really blind the oncoming traffic.I think the words you are looking for are "daytime running lights" :-) Quote Share this post Link to post Share on other sites
Driftit 2199 Report post Posted July 3, 2009 So what cars is this avalible on? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted July 3, 2009 Agree with Jochen & has been discussed here before: Law on front FOG lights being illegal in good weather is an ass - they are a permenently dipped light casting a low flat beam & when set properly & checked at WOF - they cause NO dazzle/glare to oncoming drivers & could easily qualify as a good aid for being seen by others. Check them on a beamsetter - no more glare than dip beam. Muppets that fit uncontrolled beams & not connected to high beam control (in effect driving lights) into spoilers for the "look" are the ones causing problems & if all WOF inspectors were astute enough to police these then we wouldn't have a problem. However rear fogs in clear weather are a pain in the arse - hard to distinquish from brake lights & amazing the amount of people driving with them on & completely oblivious to this & not even aware that the car has them. Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted July 3, 2009 Driving lights are high beams - so not the same as DRL's at all.... Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted July 3, 2009 Law on front FOG lights being illegal in good weather is an ass - they are a permenently dipped light casting a low flat beam & when set properly & checked at WOF - they cause NO dazzle/glare to oncoming drivers & could easily qualify as a good aid for being seen by others. Check them on a beamsetter - no more glare than dip beam. There is a school of thought that you need DRL's to create some glare so you can be seen.... Same goes for stop lamps - you need to create discomfort to really be seen. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted July 3, 2009 So what cars is this avalible on? E46 E39 E38 X5 E53 Z4 X3 ...and all later models do have DRLs as well, but NavCoder cannot program the newer cars. Quote Share this post Link to post Share on other sites
