Creaver 55 Report post Posted July 1, 2009 Hey guys, I've wired my headunit up, it turns on etc, but no sound comes out. I suspect the factory amp has something to do with this? I've read on the net if I bypass this completely, I will lose the use of the cross-over and only be able to support 4 speakers, instead of the 10 I currently have. Please let me know your thoughts and some ways of getting around this. Cheers, Ian. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted July 1, 2009 no sound at all or not from radio? Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted July 1, 2009 at all, not even static Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted July 1, 2009 have you wired 12volt switched power to the white wire that turns the amp on?? bring it around can have a quick look and measure with a meter also have spare amps ,radio's etc to test . cheers brent 021433600 around most times Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted July 1, 2009 Hey Brent, i've just had a look and no, there is nothing connected to the white wire. I don't think there ever was? I will splice it into my switched power and give it a go, if still no luck ill give you a call, thanks. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted July 1, 2009 Hey Brent, i've just had a look and no, there is nothing connected to the white wire. I don't think there ever was? I will splice it into my switched power and give it a go, if still no luck ill give you a call, thanks. should have power when the radio is switched on (not the ignition) , so normally wired to the switched output for the aerial power (blue wire from a aftermarket radio) Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted July 2, 2009 Brent - you are a f**kING LEGEND. I made the ignition problem, was about to come on here and say thanks and describe my new problem....BUT YOU'VE ALREADY SOLVED THAT PROBLEM TOO !!! A big thanks Brent. Saved me heaps of money/time. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted July 2, 2009 Ian, i had the same prob with mine when putting in the aftermearket stereo then realised it had the factory amp which i had to power up, the blue wire on the head unit is the remote amp turn on wire, just used that one. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted July 3, 2009 sometimes the blue wire or the amp power craps out in the head unit. in which case just power the amp off a accessory wire. ie cig lighter. Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted July 3, 2009 Hahaha I did the exact same thing too when I put my HD in the 540i a few months ago. Worked out what I had done wrong after a a period of cursing. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted July 3, 2009 yup been there too . fitted a aftermarket head unit that has a radio power ant output and also a amp power output . both blue , wondered why i had sound with the radio and no sound from the cd or usb harddrive etc . Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted July 3, 2009 Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted July 3, 2009 sometimes the blue wire or the amp power craps out in the head unit. in which case just power the amp off a accessory wire. ie cig lighter.Yes that's true, the amp wire in my old head unit f**ked out so i just spliced the 12V turn on wire instead. Quote Share this post Link to post Share on other sites
