minsu515 0 Report post Posted July 10, 2009 hi. im trying to remove the driverside controll arm but i cant get my tool to remove the inner balljoint bolt that is bolted in the middle. tools wont fit and there is not enough room,, does anyone know how to remove this?! Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted July 10, 2009 easyest way is to get a deep reach 17mm socket. put enough extensions on it so that you can access it through the top of the engine bay. Quote Share this post Link to post Share on other sites
minsu515 0 Report post Posted July 10, 2009 (edited) easyest way is to get a deep reach 17mm socket. put enough extensions on it so that you can access it through the top of the engine bay. tried that but its a 6cyl so dont have room from the top aswel also its a 22mm nut. can anyone please come ova and give me a hand.. i really need this car running by 15th as im moving.. cheers also I can pay if whoever helps me out gettin this off.. Edited July 10, 2009 by Mind Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted July 10, 2009 use a very long extension( or 2 or 3 joined together) with woble head . down the side of the engine Quote Share this post Link to post Share on other sites
minsu515 0 Report post Posted July 10, 2009 use a very long extension( or 2 or 3 joined together) with woble head . down the side of the engine hi brent! just tried that now, but due to the angle of the nut, the woble head wont fit with the socket on, there is another part right ontop of the nut, that leaves me 3~4cm and socket+woble head is too long and will not fit. but the socket it self fits alright. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted July 10, 2009 hi brent! just tried that now, but due to the angle of the nut, the woble head wont fit with the socket on, there is another part right ontop of the nut, that leaves me 3~4cm and socket+woble head is too long and will not fit. but the socket it self fits alright. You need a 22mm universal socket. Not a socket + a universal. Quote Share this post Link to post Share on other sites
minsu515 0 Report post Posted July 10, 2009 You need a 22mm universal socket. Not a socket + a universal. hi thanks for the reply. where can i get a universal socket? cheers Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted July 10, 2009 hi thanks for the reply. where can i get a universal socket? cheers You could try Repco... but good quality ones are a specialist tool Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted July 10, 2009 or a extension with the tapered end on it thats what i use (so you can bend off to the side a bit) Quote Share this post Link to post Share on other sites
