Forrest 35 Report post Posted July 27, 2009 ^ Then you wouldn't be any different than joe bloggs in his e46 m3 Quote Share this post Link to post Share on other sites
BM WORLD 1260 Report post Posted July 27, 2009 (edited) ^ Then you wouldn't be any different than joe bloggs in his e46 m3 "Then you wouldn't be any different than joe bloggs in his :puke: green/yellow e46 m3" Edited July 27, 2009 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted July 27, 2009 I think the S50 ECU can be remapped - you're right. The trick is finding someone who (1) can and (2) is going to know what to do to get from S50 --> S54 (which may not be that big a deal as I understand they are reasonably similar). Shouldn't you take your car down from Trademe Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted July 27, 2009 The wiring techy at RaceFx is pretty confident he can do it, aparently the only big difference between the two are the hall sensors for vanos control on the s54, which can be replaced by the s50 variable rate ones. Yeah im just letting it run till the end. Quote Share this post Link to post Share on other sites
