bmwsparkle 3 Report post Posted November 29, 2004 thinking about ripping my air con out and wiring the air con fan up to the air con switch to act as an electric fan, either that or wire the air con fan up to a seperate switch so i can run both or, rip all out and put an electric fan in what do you guys think? sparkle Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted November 29, 2004 Electric fans don't flow any where near as much as the engine fan, esp. not the air con. fan. Have it as an extra, sure, but not as the only fan. If you want to remove the engine fan look for the fans off a AU falcon, they have a twin fan setup complete with shroud that mounts to the back for the radiator. Why do you want to ditch the air con. any way?? Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted November 29, 2004 oh i didnt mean as the only fan, just as an extra, air con is v heavy (not that its an issue with my car), it apparently sucks power too. also thought it might block quite a bit of the excess air that im going to create with an extra fan Quote Share this post Link to post Share on other sites
E34-535ti 5 Report post Posted November 29, 2004 Are you actually having overheating problems??? if you are it would suggest you have problems somewhere, it shouldn't overheat if the cooling system etc is working properly.... Plus aircon is so nice to have. Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted November 29, 2004 well my heater isnt really workin so maybe... but yuh Quote Share this post Link to post Share on other sites
BM WORLD 1289 Report post Posted November 29, 2004 easy to fix the heater valve ,pull it apart and clean out or get a 2nd hand one ,i have some i think . Quote Share this post Link to post Share on other sites
