Creaver
getrag 260/6 fluid
My mate wants to change his gearbox fluid in his m30 powered e23 (735i) with manual trans. What type of fluid is recommended/do you guys use?
The bentley suggests atf for 535i getrags.
cheers,
Ian.
I have always run normal run-of-the-mill ATF in the getrags I've had and it's worked absolutely fine.
G3 full synthetic or for harder driving (higher loads) use 75w80 full synthetic
I wasn't aware that you could use ATF in a manual gearbox without problems later on. Are there any advantages to using ATF?
ATF G3 full synthetic is the correct oil for most pre-1998 BMW manual cars
Edited by *Glenn*
