volcanoblack
Original Options on 1993 325i How to find out?
I have looked on the forums and used all the VIN decoders to find out what options are installed from the factory on my 1993 325i. Are there option codes printed on a sticker on the car somewhere - like Audi does?
Question remains - do all 325i come with a limited slip differential? This is not listed anywhere on the VIN decoders. How do I tell?
Here is what I know so far:
    Type code     CB32
    Type     325I (EUR)
    Dev. series     E36 (4)
    Line     3
    Body type     LIMOUSINE
    Steering     RL
    Door count     4
    Engine     M50
    Cubical capacity     2.50
    Power     141 Kw
    Transmision     HECK
    Gearbox     MECH
    Colour     GRANITSILBER METALLIC (237)
    Upholstery     SILBERGRAU LEDER (0483)
    Prod. date     1993-05-27
    Order Options
    No.     Description
    199     EQUIPMENT FOR LEADED FUEL
    411     WINDOW LIFTS, ELECTRIC
    498     HEADRESTS IN REAR, MECHANIC. ADJUSTABLE
    530     AIR CONDITIONING
    548     SPEEDOMETER WITH KILOMETER READING
    564     INTERIOR LIGHT PACKAGE
    687     RADIO PREPARATION
    806     NEW ZEALAND EXECUTION
    818     MAIN BATTERY SWITCH
    850     ADD FUEL TANK FILLING FOR EXPORT
    925     SHIPPING PROTECTION PACKAGE
Thanks
there may be a paper in the car ,under the rear seat is common,mine was under the front seat.Take the vin to the dealer,ask nicely for a build sheet.Actually you only need the chassis number which is last 7 numbers of vin
No, its an option for all cars. Only standard on M3 AFAIK.
If it was optioned for your car then it would list it with the other options.
No. Look for the tag on the diff that states the ratio. If it starts with an 'S' it's a LSD.
Guest FrantiC
Yeah usually standard on motorsport models and in m3's every other was available as an option..
Park one wheel on grass and one wheel on tarmac/road/driveway and find out?
Or just jack up and spin one wheel. If the other spins the same way celebrate
209 LIMITED SLIP DIFFERENTIAL (25%)
that is what you would see on the build sheet
Would that not depend on the type of pre load or type of lsd whether or not the oposite wheel rotates the other way whilst under no load?
Yes but it works on these LSDs.
Super rare option on a E36.
