antil33t
Broken Bonnet Release....
So, I couldn't open my bonnet today... turns out the cable has broken (the wee metal peice that sits in the plastic handle has broken off)
Dad reckons we can solder another peice back on,
But i need to remove the whole cable....
Where's the manual release?
thanks.
Behind the passenger side grille. Poke a flathead screwdriver in the hole and push down. Sorry I don't know where to look for a pic but you will get it.
My cables broken aswell, pliers can open it...try that then it'll be easier to get it out no doubt
Happened to a BMW my mate bought ages ago. The release had broken like that too, he just used some pliers to pull the cable.
if you need another one let me know , i have one , not sure when the scrappy is coming to pick the car up but should be able to get it out
Cheers guys, Will have a look in the daylight tomorrow :)
This.
Looks like a hole with a slot in it just below the latch under the bonnet in front of the car.
Put the screwdriver in the slot and twist.
Anyone know which hole?
theres a few.. I've allready accidentally screwed up the headlight adjustment... whoops :P
Guest FrantiC
Watch your head too, Cos it pops forward when it releases.
= pwned in the forehead.
Cheers man, Help much appreciated :D
I was looking in the wrong places.
Edited by antil33t
