User Name
Shifter mount - is it worth having
Hi Guys
See link below
http://www.realoem.com/bmw/showparts.do?mo...hg=25&fg=05
this is a part that i currently dont have no my manual conversion along with a reverse switch but instead have just bolted up the shifter to the underside of the car and seems fine.
but is it worth getting the extra bits so it looks better or if it goes just leave it as is.
also if anyone has any how much??
Which part don't you have? There are 13 different parts shown in the diagram.
I dont have any of that - i just basically Screwed the mounting arm to the car instead of having all the pretty cover etc seen i didnt have it and left it
so does having all the shifter mounting parts acutally matter - as it shifts gears fine just a gapping hole to the ground and exhaust
Guest FrantiC
What's missing?? The rubber boot to fill the hole, Or shifter linkage??
Does yours look more like this??
Posted Image
Yea that looks like it - but the first link i put is actually the holder that bolts onto the back of the gearbox and sits up against the car
dont think itl be a biggy - going to get my selector rod cut tommorow so if that goes well its going to drive anyway
Nah there is two different types. The one you think you should have, and the one bravo showed you.
You probally have the one bravo showed. So you dont need the other parts.
Thanks Guys
ill just sus the reverse sensor lolz only thing i dont have
