User Name 19 Report post Posted August 20, 2009 Hi Guys My Getrag 260 has a sensor on the side of the box (out of a e32) and im geussing that i need to wiring this into the speed sensor input on the motronic 1.3 wireing harness - i was using a wire off the coil to the speedinput and the car seemed to go fine. but now i had to take that wire off for wof reasons, do i just need to wire it up or is there some testing i should do first Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted August 20, 2009 motronic 1.3 does use a bellhousing sensor , it uses a crank hub sensor and a ref cable around one of the spark plug leads . what is this going into?? , what have you modified ??? the older motronic 1.0 and 1.1 use a crank angle an dref sensor mounted in the bellhousing and you need a flywheel with a pick up point for it to work , but this was only used in e28 535i e24 535i e23 735i from about 1982 till 1987 e28 528i use l-jetronic Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted August 21, 2009 Hi Brent The engine is the M30B35 i got off you awhile back out of a E32, and the Getrag 260 box i have said it was out of a e32 and has a sensor on the side with two wires hanging off using motronic 1.3 - so dont know if i need to do anything with these wires?? - can they be connected to the Tachomater as i major failed and couldnt find some of the wiring connections for Tacho so just connected it to the coil but when i hit i big bumb it falls off. Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted August 21, 2009 thats right you dont need the sensors on the side of the gearbox . tacho comes off the fat greem wire in teh engine loom Quote Share this post Link to post Share on other sites
