antil33t 90 Report post Posted August 30, 2009 Politicians that want to drive up the stairs of parliament would approve of square wheels. Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted August 30, 2009 I removed the power steering setup in my old Integra and it failed the next wof I went for. Dont know wether that should have happened or not but they told me I would have to put a manual steering rack in. So if the car has a PS rack installed then it has to be operating as a PS rack? This was at a VTNZ also. My 2c Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted August 30, 2009 Is a looped P/S rack just what it sounds to be? You just remove the P/S pump and loop it? Mean. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted August 30, 2009 You need to remove the full system, rack pump tank etc , and fit a manual non powersteering rack Ray will have one so just call him before making another wanted thread. you can loop the old rack but it wont pass a wof, and it wont last very long either. Quote Share this post Link to post Share on other sites
Quinn 1 Report post Posted August 31, 2009 Did you clean out the filter at the bottom of the reservoir? When I took my car into Auckland Powersteering Specialists they pulled it out an it was black as, After about a minute of blasting with compressed air and a few flushes it came up clean and so did the fluid. Probably part of the problem in your case... Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted August 31, 2009 I didnt take the pump off, just drained it. Am waiting for Matty to reply? May go to his mechanic to flush it ...? Quote Share this post Link to post Share on other sites
Quinn 1 Report post Posted September 4, 2009 I didnt take the pump off, just drained it. Am waiting for Matty to reply? May go to his mechanic to flush it ...? Like I said, try cleaning out the filter at the bottom of the reservoir. Its easy and it made a huge difference to the fluid. Quote Share this post Link to post Share on other sites
