Andrew 30 Report post Posted August 30, 2009 Hello - Any of you E39 electrical hackers know a way to change the dash to read kms in the odo instead of miles? This is a 1999 540. Cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 30, 2009 If it has OBC, you might be able to do it through there... or else with scanner software only Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted August 30, 2009 If it has OBC, you might be able to do it through there... or else with scanner software only The OBC had the option to change OBC units - but not the dash. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 30, 2009 The OBC had the option to change OBC units - but not the dash. Do you have a BC switch on the indicator stalk and multi function steering wheel ?? Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted August 30, 2009 Do you have a BC switch on the indicator stalk and multi function steering wheel ?? Yep - Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 30, 2009 Yep - Scroll through the options and see if you can get a menu to change it ...if not, its a scanner only job Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted August 31, 2009 Scroll through the options and see if you can get a menu to change it ...if not, its a scanner only job Thanks Glenn - will let you know how it goes. Quote Share this post Link to post Share on other sites
