RyanG 0 Report post Posted September 13, 2009 Does anyone have a rough of idea of a price for an m52b28 headgasket? I just need the gasket. thanks Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted September 13, 2009 $100? Probably less. Give Gavin at Euro Italian a call. He'll do you a great deal. Quote Share this post Link to post Share on other sites
RyanG 0 Report post Posted September 13, 2009 Thanks. Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted September 13, 2009 I base that on the price of a brand new M20 headgasket I had, which I got priced up at about $60. So it actually should be less than that. Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted September 13, 2009 i have a spare gasket . not used in a project . Quote Share this post Link to post Share on other sites
RyanG 0 Report post Posted September 13, 2009 How much do you want for it? Quote Share this post Link to post Share on other sites
RyanG 0 Report post Posted September 14, 2009 $190 + gst.... Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 14, 2009 Try somewhere like Repco. Quite abit cheaper, but of less quality. Quote Share this post Link to post Share on other sites
RyanG 0 Report post Posted September 14, 2009 I used repco gaskets once before. Never again. All the rubber bits split in about 2 days. They also wanted $110 for a serpentine belt. Quote Share this post Link to post Share on other sites
euroitalian 63 Report post Posted September 14, 2009 Doubtful Repco would stock these anyway, as they are an MLS gasket. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 14, 2009 That is pretty cheap if it is an MLS then. Mine for the m20 cost me $426 shipped from the U.S. Quote Share this post Link to post Share on other sites
RyanG 0 Report post Posted September 14, 2009 Euro-Italian said: Doubtful Repco would stock these anyway, as they are an MLS gasket. Are they MLS standard? Or are you selling aftermarket ones? Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 14, 2009 (edited) Wait on - Isn't an MLS headgasket reusable ? Edited September 14, 2009 by FrantiC Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 14, 2009 FrantiC said: Wait on - Isn't an MLS headgasket reusable ? You never reuse a headgasket Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 14, 2009 *Glenn* said: You never reuse a headgasket What about MLS ones ? Is OEM different, I'm not sure... But Cometic ones you can re-use. It's not like they perish or deform. Quote Share this post Link to post Share on other sites
RyanG 0 Report post Posted September 15, 2009 *Glenn* said: You never reuse a headgasket You can reuse Cometic MLS ones. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 15, 2009 RyanG said: You can reuse Cometic MLS ones. Where did you find that info? I couldn't find it on the Cometic websites. I dont want info from a random on some overseas forum. I'd like to see the manufacturer saying it can be reused. I'm not saying your wrong... I cant find the info. Most headgaskets have a crushable ring around the combustion chamber that crushes when the head is torqued, therefore it can only be used once. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 15, 2009 Not directly from Cometic, But on sites selling cometic they claim they can be reused up to 4 to 5 times, before the spring embossments lose their memory. http://www.spottsperformance.com/cometic%20head%20gaskets Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 15, 2009 I still wouldn't on a road car. And I'd still like to see if Cometic endorse the reuse of their product. I couldn't find anything relating to it. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 15, 2009 Neither could I to be honest. If you google it, there are people re-using them a few times even in race car applications. Luke re-used his in his m50 turbo.. I would be very wary of re-using one though, especially with high amount of K's on it. Though they are only a piece of steel with 2 thin sheet steel plates riveted onto each side which have the sealant on them. Cometic do suggest removing the rivets and spraying copper spray between each layers and on the outside if you issues with them sealing. Quote Share this post Link to post Share on other sites
RyanG 0 Report post Posted September 15, 2009 *Glenn* said: I still wouldn't on a road car. And I'd still like to see if Cometic endorse the reuse of their product. I couldn't find anything relating to it. I doubt they would say it on their website as it could become a problem with warranties etc. AFAIK they dont have a crushable ring like conventional head gaskets, and reusing them is fine. Quote Share this post Link to post Share on other sites
