c.robertson00
FS: Cheap E30 Junk
I need to clear out my e30 stuff. Il find some more stuff and put it up
E30 Rear Sway Bar $35
E30 Wiper Motor $20
E30 Facelift 318i Fuel Pump... The one in the tank $30
E30 51mm Struts, Pair What are they worth? Offers?
E30 Under Dash Panel on Drivers Side $30
E30 Pair of Front Callipers Good Condition
E30 Facelift Rear Tail Lights $50
E30 4.45 small case open diff $70
Glovebox mint condition $10
Rear windscreen $70
318i facelift radiater $80
Rear Monroe Gas Shocks, Pair Good Condition $40
Left rear Quater Light of a four door $20
E30 318 Altenater $25
E30 Starter Motor- Small Type $25
I will be in Wellington this weekend so can bring them down with me
Text me on 0277887500
Cheers Chris
Edited by chris00
"E30 Facelift 318i Fuel Pump... The one in the tank $30"
Hi Chris,
I don't suppose you could post a pic of the fuel pump could you? I am looking for an in tank pump and level sensor for my e21 2.7 conversion. I supposedly need the pump from a 318is e30, but perhaps the later 318 is the same.
Thanks
Daniel
Any luck with those photos chris?
Here the lights and glove box mate. The lights look like there brand new and the glove box has abit of scum on it that will come off with hot soapy water. I just didnt have enough time
Edited by chris00
Hi Chris,
Thanks
Daniel
Heres a few pics of the pump. Its been kept in a sealed bag since i pulled it out of the car and works fine. The pumps should be the same. Ime sure all the pumps are the same?
Sway bar and glovebox is mine :P
