APT 199 Report post Posted September 15, 2009 (edited) Ok its only been now that ive started to drive my e30 more regularly and have a few questions regarding little problems. 1. When shifting through gears it isnt as smooth as id like it to be, is there a bush/cup or something that i can replace to solve this ? 2. I get a little wobble in my steering wheel when i go about 90+ kms.- Lower Control Arm Bushes ? 3. There is a tapping sound coming from my engine, it occurs at random times though. (Very annoying sound against the m20 rumble) lol 4. My Window wipers gets stuck at the slowest setting but works 100% at the faster settings. Any advice/suggestions would be awesome Thanks Bimmersporters. Edited September 15, 2009 by APT Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted September 15, 2009 3. There is a tapping sound coming from my engine, it occurs at random times though. (Very annoying sound against the m20 rumble) lol 4. My Window wipers gets stuck at the slowest setting but works 100% at the faster settings. 3. Possibly Tappets need ajustment? 4. I've had this problem too, Heres how I fixed it. http://www.e30zone.net/e30zonewiki/index.p...en_Wiper_faults Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted September 15, 2009 1. When shifting through gears it isnt as smooth as id like it to be, is there a bush/cup or something that i can replace to solve this ?Short shifter and the two bushings that I can supply you. makes a world of difference. and maybe some new gearbox oil.2. I get a little wobble in my steering wheel when i go about 90+ kms.- Lower Control Arm Bushes ?Get a wheel alignment Quote Share this post Link to post Share on other sites
APT 199 Report post Posted September 15, 2009 Is the shortshift kit a substancially shorter throw? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted September 15, 2009 Get a wheel alignment + Balance Quote Share this post Link to post Share on other sites
APT 199 Report post Posted September 15, 2009 Got one from hyper about 600ks both wheel alignment and balance. Cheers for the advice guys Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted September 15, 2009 Is the shortshift kit a substancially shorter throw?Definitely noticeable, but not overkill. Ive seen/tried other short shift kits in E30s and comparitively this one is a nice gentle, but noticeable one. Quote Share this post Link to post Share on other sites
APT 199 Report post Posted September 19, 2009 okay got two more problems. 1. At times my e30 is hard starting, say at the start of the day, so far the only things i have only carried out regarding ignition are spark plugs. Do i have to change the spark plug wires ? 2.This isnt really a problem but more of a question, i was cruising on the motorway the other day and at 100kph and i was at 3100 revs is this normal ? it seems abit high to me. Thanks Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted September 19, 2009 (edited) Ok its only been now that ive started to drive my e30 more regularly and have a few questions regarding little problems. 1. When shifting through gears it isnt as smooth as id like it to be, is there a bush/cup or something that i can replace to solve this ? 2. I get a little wobble in my steering wheel when i go about 90+ kms.- Lower Control Arm Bushes ? 3. There is a tapping sound coming from my engine, it occurs at random times though. (Very annoying sound against the m20 rumble) lol 4. My Window wipers gets stuck at the slowest setting but works 100% at the faster settings. Any advice/suggestions would be awesome Thanks Bimmersporters. 1. Get SIR E30s short shift kit, they are good. Also get the brass bushing he can supply you. And as he said, try new oil 2. Try another wheel alignment 3. Typical m20 lol. 4. Wiper motors getting old, replacing them is a bastard of a job I've been told. I think possibly you can just clean them out... okay got two more problems. 1. At times my e30 is hard starting, say at the start of the day, so far the only things i have only carried out regarding ignition are spark plugs. Do i have to change the spark plug wires ? 2.This isnt really a problem but more of a question, i was cruising on the motorway the other day and at 100kph and i was at 3100 revs is this normal ? it seems abit high to me. Thanks 1. Cant say for sure, could be a number of things. 2. In each gear and a certain speed you will always do the same RPM. For example, every time you are in 5th, doing 100kmh, you will do 3100rpm. The only way this can change is if your clutch is slipping, and it wont be that. Edited September 19, 2009 by Mark247 Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted September 21, 2009 okay got two more problems. 1. At times my e30 is hard starting, say at the start of the day, so far the only things i have only carried out regarding ignition are spark plugs. Do i have to change the spark plug wires ? 2.This isnt really a problem but more of a question, i was cruising on the motorway the other day and at 100kph and i was at 3100 revs is this normal ? it seems abit high to me. Thanks Re the wires, generally no you don't on the e30 unless they are obviously arcing or worn etc. Did you gap your plugs correctly and are they the correct plugs for the e30? Hard starting can be a host of things. I have always found the e30 to be a great starter when cold but require a little cranking at times when hot. Check that any cold start circuits are functioning - check temp sensor for a start. Yes, 3100 does seem high for top gear. What wheel/tyre sizes are you running? Is it still the standard diff ratio? Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 21, 2009 (edited) You probably have a 4.45 diff ratio, It's higher ratio so you have really short gear changes. i.e max speed in 1st, 40km/h, 2nd is about 80km/h, 3rd 110km/h etc. Just get a shorter ratio dif. My 3.64 cruises at 2500rpm @ 100km/h. Max speeds (6200rpm limit) 1st gear 50km/h, 2nd gear 95km/h, 3rd gear 145km/h and so forth.. Edited September 21, 2009 by FrantiC Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted September 21, 2009 4. I've had this problem too, Heres how I fixed it. http://www.e30zone.net/e30zonewiki/index.p...en_Wiper_faultsMe too, it takes a bit of time to get the motor out and you WILL lose skin from your knuckles but its an easy fix and very rewarding to have your wipers working nicely. Quote Share this post Link to post Share on other sites
APT 199 Report post Posted September 21, 2009 This weekend i will be making my window wipers work 100 % hopefully Quote Share this post Link to post Share on other sites
