wolliver 1 Report post Posted September 17, 2009 ok, so i want to see how good you guys really are. engine is not starting, it cranking fine and battery is good. have no spark in all 4 cylinders (4A-FE engine), sparkplugs are fine, HT leads to sparkplugs are fine. What can would cause this, keeping in mind its electronic ignition. im guessin it could hav something to do with the CPS??? maybe its faulty or something? i dont know. please help cheers, James Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted September 17, 2009 ok, so i want to see how good you guys really are. engine is not starting, it cranking fine and battery is good. have no spark in all 4 cylinders (4A-FE engine), sparkplugs are fine, HT leads to sparkplugs are fine. What can would cause this, keeping in mind its electronic ignition. im guessin it could hav something to do with the CPS??? maybe its faulty or something? i dont know. please help cheers, James igniter box!? Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted September 17, 2009 where bouts is the igniter box and how do i test it?? Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted September 17, 2009 where bouts is the igniter box and how do i test it??its either on the fire wall or on lh inner guard , its off your engine loom, has 2 plugs, best way is to try another one as im not to sure how to diagnose zorry Quote Share this post Link to post Share on other sites
laadeelaa 0 Report post Posted September 17, 2009 Give Glenn a call? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted September 17, 2009 ok, so i want to see how good you guys really are. engine is not starting, it cranking fine and battery is good. have no spark in all 4 cylinders (4A-FE engine), sparkplugs are fine, HT leads to sparkplugs are fine. What can would cause this, keeping in mind its electronic ignition. im guessin it could hav something to do with the CPS??? maybe its faulty or something? i dont know. please help cheers, James So 4A-FE engine in what? Beemer? If so then could be anything as nothing is standard OE Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted September 17, 2009 It'll be some form of Toyota Corolla. If it's new enough, it might be worth taking it to a dealer/mechanic/auto sparky and having it put on the computer. Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted September 17, 2009 So 4A-FE engine in what? Beemer? If so then could be anything as nothing is standard OE na its in a corolla Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted September 17, 2009 (edited) couldnt help myself Edited September 17, 2009 by 323e30 Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 17, 2009 Sounds likely to be CPS. Same thing with the m20, If the crank sensor is bad then the ECU can't determine which position the crank is in and there-fore doesn't fire.. I dunno about those engines and their electrics, but alot of them the igniters aer built into the ECU? Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted September 17, 2009 To cheak a crank position sensor you check the resistance accross the 2 coil terminals. If it fluctuates the its fine. if the reading stays the same then your sensors crook Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 17, 2009 From memory, the 4A-FE doesnt have a CPS with a seperate igniter. It has the ignition igniter inside the distributor and is triggered by camshaft rotation. You can pick them up quite cheaply. What year is the car ? Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted September 18, 2009 your right glen doesnt have cps, but i found the fault. it was a crap ignition trigger wire, was like a 3.5v drop or sumfing across the wire so it wasnt triggering at all... took a while, read the manual but i got there in the end and just replaced the wire Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 18, 2009 your right glen doesnt have cps, but i found the fault. it was a crap ignition trigger wire, was like a 3.5v drop or sumfing across the wire so it wasnt triggering at all... took a while, read the manual but i got there in the end and just replaced the wireAll good then... glad you got it sorted.. Christ !! I havent worked on one of those for at least 12 years Quote Share this post Link to post Share on other sites
