robertw 0 Report post Posted September 21, 2009 Hi Guys, My 325i overheated a little last night not to serious no warning from OBC just straight to redline then dropped back to 3/4 mark, got where I was going waited for it to cool down topped radiator and drove home OK, checked this morning no sign of leak ran up to normal temp in about 10mins and stopped at the 1/2 mark, fan spinning OK I have only had the car a couple of months, gave her an oil change a month ago, topped the radiator a couple of times when the OBC has indecated low coolant only need small amount 250ml or so, Car had been hanging around dealers for the last two years only clocked up 5000k in that time, so unlikely to have had any services in that time, plan on giving cooling system a flush, Question! what do you think I should do as well as flushing? Car has 136k on the clock, would the water pump have been changed by how I understand the orginals plastic implers go early on, is it worth putting a new pump in on the off chance. Cheers Robert. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted September 21, 2009 It needs to be checked properly... you will have a leak Quote Share this post Link to post Share on other sites
robertw 0 Report post Posted September 21, 2009 Thanks Glenn, Stuck out West until next week will book it in when I get home Robert. Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted September 21, 2009 (edited) had the same problem on my one. culprit: water pump f'd up: my one still had the plastic one. it started to disintegrate it left debri inside the cooling, clogged up the thermostat and radiator and heater core. ( or it could be the fan clutch or belt not turning your waterpump) solution: flush out radiator [ i replaced mine as top inlet hose connector was wasted], replaced waterpump, replaced thermostat, replaced hoses and took out heater core and replaced, flushed system 3 times. the plastic waterpump Edited September 22, 2009 by Docile Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted September 22, 2009 also double check how good the fan viscous clutch is working , if it spins realy freely then its stuffed also will be realy oily in the front of the fan clutch if its lost all its fluid from teh clutch unit . Quote Share this post Link to post Share on other sites
