Jamez
Wheel Crack
I got some new wheels and one of them has got a small crack on the inside that has separated a little.
1.Is it repairable?
2.At what cost?
3.Where do i go?
4.Should I repaint the centers?
Edited by Jamez
arrow wheels can repair it for sure man
Guest Ari Gold
Brugars on the shore if arrow can't.
Widths / offsets / etc James?
They looks like MX5 RS'?
they are pretty narrow and don't have that much dish :(
15x6.5 4x114.3 +44
and there make name is "Volk Racing Super Fine Rim by Rays Engineering" 3 piece
Edited by Jamez
im thinking 20mm spacers so its at +24
whats a good tire size for 15x6.5's? I have a set of 205/55/15's but I have a feeling they will be to wide.
also what saw cut's threw tire best as I cant stretch to spending $5 for someone else to take the bald ones off.
Edited by Jamez
hacksaw, maby angle grinder if you are carefull
Just cut thru the sidewall with a stanley knife. Its pretty easy. Then just cut thru the bead with a chisel and hammer or somthing, just be careful not to damage the wheel.
Easily Fixable
You should send them all 4 rims to be checked over, don't another crack appearing from a diffierent rim or from a hairline crack not visible under some crud.
Mac-weld
based in Drury.
just had my schnitzers un-buckled and lip polished.
can weld etc.very reasonable pricing and great end results.
marty very happy
Brugar on Barrys Point Rd. Should cost around $60-$80 at a guess. Does very good work.
got a quote from Arrow Wheels for $150+gst, that' more than i payed for all 4 so im going to give Brugar a go tomorrow, hopefully they can do it for under $100.
one of my rs' had a crack almost identical to that. $70 cash and had them back the next day. was in Christchurch though.
Edited by brockie123
