Guest FrantiC Report post Posted September 23, 2009 A friend of mine has a 1988 735i e23. It has abit of a brake problem, where the brakes are 'dragging'. Was told this was the issue by a mechanic who fixed a few other various things on the car. He has replaced the rear rotors, Not entirely sure why, but aparently it is the front brakes that are dragging. BMW suggested it would be the Brake pressure regulator http://www.realoem.com/bmw/showparts.do?mo...hg=34&fg=25 Does this sound likely to be the cause? I haven't checked out the car, my mate is in the army so he only has time on weekend's to sort it out (he's now asked for my help). I've just never worked with a 735i before Lol. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 23, 2009 (edited) It may not have the correct pushrod clearance/freeplay from the brake linkage to the servo which is adjusted inside the car. It could be the servo jamming as well. Needs to be checked properly. I doubt it is the pressure accumulator. Edited September 23, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 23, 2009 Well I got him a replacement pressure accumulator from Brent on here, Would it be worth replacing anyways since I made him fork out $100 for it? lol What should the pushrod clearance be and where would i find it? I assume if i looked at it without the brakes being pressed, it should have freeplay then? And if it is engaged there is an issue? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 23, 2009 Release the brake pipe on the master cylinder with your foot off the brakes for the front brakes and see if there is pressure there. And check to see if the brakes free up when you do this. If they dont free up its probably the callipers sticking in the slides. Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted September 23, 2009 e23's are well known for having sticky brake calipers . check all of them Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 23, 2009 e23's are well known for having sticky brake calipers . check all of them Will do, Probably won't get a chance to look at it til next weekend or the week after. If the calipers are sticking, what is the solution to that? And I guess to check this, You would check how freely the wheel rotates while jacked in the air - No brakes applied, Correct? Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted September 24, 2009 Will do, Probably won't get a chance to look at it til next weekend or the week after. If the calipers are sticking, what is the solution to that? And I guess to check this, You would check how freely the wheel rotates while jacked in the air - No brakes applied, Correct? yes thats right , just spin teh wheel . maybe take them apart , clean and lube etc , or get them overhauled ,new seals etc ,reco'd etc . or just try some second hand ones . Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted September 24, 2009 Um, maybe this is a dumb question, but are you sure it's an E23? I thought they were replaced by the E32 in 1986? Is the year wrong, or do you mean E32? Cheers Quote Share this post Link to post Share on other sites
