wolliver
M10 cam timing chain removal
Why do you need to remove it?
Edited by CamB
From memory, undo four bolts and remove sprocket.
I concurr with Cam. Remove the top timing cover (the one attached to the head) then just remove the 4 bolts holding on the cam sprocket and you should be able to remove the sprocket.
Sometimes I've found it helped to remove the chain tensioner, (the M19? cap on the the exhaust side) but it shouldn't be absolutely necessary.
