Palazzo 522 Report post Posted September 29, 2009 In the middle of a cam belt replacement, someone accidentally spun the engine over for about 1 sec and after it was put back together, it missed like crazy. What are the likely scenarios? Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 29, 2009 (edited) I hope you don't mean they cracked the engine with the starter?? Stationary valves and a moving bottem end isn't going to end up good with a interference engine. Pretty much like breaking a timing belt, the pistons all get hit into the valves, bending them. On the odd occasion they break through the tops of the piston too. Edited September 29, 2009 by FrantiC Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted September 29, 2009 Bent valves or the belt has jumped a teeth or 2. By the sounds, the timing is out. Recheck timing. If that's fine, pull the head again. Ouch. Quote Share this post Link to post Share on other sites
Palazzo 522 Report post Posted September 29, 2009 Yes I know the likely scenario is not good, let's hope for a timing belt jump. Not optimistic though. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 29, 2009 What actually happened?? spun by hand or cranked over with no belt on? I think since it is running, that is a good start. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 29, 2009 (edited) If the belt wasnt on when it was turned over, you will have bent a valve or two. You can check this first before taking the head off with a cylinder leak test. Edited September 29, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
Palazzo 522 Report post Posted September 29, 2009 Cranked on the starter, not sure if the belt was on loosely or not as I wasn't there. Guess I won't be heading to Wgtn tomorrow after all, unless I get real lucky. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted September 29, 2009 Pulled the valve cover off?? Could have broken a rocker arm or something. Quote Share this post Link to post Share on other sites
