User Name 19 Report post Posted September 29, 2009 OK Guys, Maybe not right place to ask, but i can always move it if needed i am thinking about stroking my M30 - now i know the available options some of which arnt going to happen cause or rareity of parts but i just wanted to know, how you change a crank shaft to increase stroke on a engine i read some stuff on the net but i am actually lost and throught someone might bout to put it in english haha eg. say i want to increase the stroke on the m30 to 94mm which would increase the capacity to around 4 litres. could you do this using 3.5l crank modified etc - im prob sure that i would need a custom crank for something like this $$$$ but what are the possiblitys or just a explaination - how grinding etc a crank shaft would increase stroke Cheers kym Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted September 29, 2009 you wont get 4L easily . using readily availible parts teh best is about 3.6L easist option is a 3.5l from a e34 , e32 etc. or e28 , e23, e24 or go for the early very 3.5L with 84mm and fit the later 3.5l 86mm crank etc and get about close to about 3.6L if you do a over bore with custom pistons then you get some where near 3.7L Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted September 30, 2009 Thanks Brent see the options available and i now you can make close to 3.7l like marty did which is good, but still comes down to would really like to know how you change a crankshaft by griding etc makes no sense and would be soo keen for a 4 ltr M30 turbo think it would be something new its the cost of the custom crank quoted around 3.5k US im sure itl be arround the same in nz - is the power gain worth the $$$ or do i just put that cash into making the build slighltly more engineered Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted October 4, 2009 but still comes down to would really like to know how you change a crankshaft by griding etc makes no sense It is called "offset grinding" and what the engine ship does is grind the bearings for the big ends off centre to where they were, the centres are ground further away from the crankshaft centreline, which is a cheap way of making a "stroker" crank. What it also means is that the big ends are now smaller in diameter than they used to be (not always a bad thing) so you need to find rods and bearings to match the smaller size. Only really achievable on some engines, and the gains are usually only 200cc or so. So probably not a cost effective solution for you, it usually a last resort to squeeze more capacity out of an engine when no other options exist. Quote Share this post Link to post Share on other sites
