User Name
Suspension Swap Question
Ok Guys - question even tho its proberly being answered before
what sort of mission is it to swap suspension for eg. e30 into a E28
as looking on the internet i see all the top camber plates seem to be universal for the both,
so my thought is that is only the bottom the mount that would cause the issue. - ive looked at realoem
fronts e28 http://www.realoem.com/bmw/showparts.do?mo...hg=31&fg=10
e30http://www.realoem.com/bmw/showparts.do?model=1412&mospid=47283&btnr=31_0112&hg=31&fg=10
rears e28 http://www.realoem.com/bmw/showparts.do?mo...hg=33&fg=45
e30 http://www.realoem.com/bmw/showparts.do?mo...hg=33&fg=45
they do look diffrent but how hard would it be to modify and pass a wof or do you reakon you could do it without as i know parts for e30's are widly avalable
but if this is not possible then sweet as it was just a thourghts on this were
Why? The E28 setup is as good as the E30, better in fact as you have 5 stud, and a much better range of wheels. Some people even go the other way and swap the E28 subframe into an E30, it's stronger and has bigger axles. It would be a lot of pain for no gain as far as I can see.
