louis297
e30 exhaust swap
have got a exhaust like this http://www.nzkw.com/exhaust/twin_1.jpg
wanted to swap for something quieter/ different like this http://www.mufflermall.com/images/mufflers...Muffler.jpg.JPG
exhaust sounds great if your in chch welcome to hear it just want to swap for something different
would prefer the tiwn tip circular one but show me what you got ,
only looking to swap like tips ? can you cut them off then weld the new ones on ? :mellow:
louis
The one you already got is way better IMO. I got one like that, off Trademe. Put it on and sounds good (not noisy at all unless I rev the hell out of it) and looks the goods too. Why dont you want yours?
I know we used to own this car, but i forgot!.. is it twin pipe into the muffler?
I just want a small one with 2 circle pipes that is quieter and looks nicer
here are pics the reason its loud i guess is the massive pipe underneath lol. i just wanna swap the tip anyway so help would be appreciated. Would I just cut the end twin pipes and weld a new one on ? I just want something different :rolleyes:
[e] Pics removed for now, PM sent :)
Edited by Penry
Thanks for using up all my internets.... resize your pics!!!  :unsure:
Changing the tips will not quieten the exhaust, nor is the noise due to the large single pipe running under the car to the rear muffler, the noise is due to the muffler itself.
If you don't like the tips then just replace them, - are they welded on?
yeah i started understanding that. the twin pipes are welded on can I cut them off and add a new end on ?
Yep, you can cut those tips off and replace them with a couple of straight stainless tips. You may be able to cut the tips off so that the replacement tips are angled in the direction you want. Is that muffler almost shot? The big single pipe looks factory, later versions had twin pipes of smaller diameter.
