e30_1uzfe 0 Report post Posted October 22, 2009 5STUD HUB CONVERSION FOR MY 1UZ FE V8 E30 I can't wait to see this! Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted October 22, 2009 You will need e36 front struts, offset bushes for the front and a e36 ti hatch rear end to convert it. Im pretty sure ray will be able to put a package together for you. Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted October 22, 2009 You will need e36 front struts, offset bushes for the front and a e36 ti hatch rear end to convert it. Im pretty sure ray will be able to put a package together for you.See I told you compacts were good for something Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted October 22, 2009 all you NEED to complete this in the cheapest, but most effective, way is e36 ti trailing arms complete with hubs, and e36 front hubs. then get a sleeve machined to fit the e36 hub to the e30 strut. Dont mess around with e36 front struts they're a bitch to get to fit right and imo not worth it. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 22, 2009 Using the Ti rear end, you'll also need the E30 M325i rear axles which are different to the 318's and 320's. They have larger joints and thicker axles and you'll also need to use a medium case diff with the right ratio and I'd also go LSD. The Ti's only come out with small case diffs and with your HP you'll need the stronger diff and axles... I had to do this with my conversion. If your car has ABS there is also a mod that you need to do with the speed sensors. You can ring me for more info if you need it (09)2722546 BTW: Welcome to the forum... that will be some beast once youve got it all sorted. Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted October 22, 2009 Ti's have smaller brakes than the 325i do they not? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 22, 2009 Ti's have smaller brakes than the 325i do they not? Larger diameter but non vented.. I'm running standard rear brakes with 328i callipers and rotors up front with no problems. 75% of braking is all in the front anyway Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted October 23, 2009 Using the Ti rear end, you'll also need the E30 M325i rear axles which are different to the 318's and 320's. They have larger joints and thicker axles and you'll also need to use a medium case diff with the right ratio and I'd also go LSD. The Ti's only come out with small case diffs and with your HP you'll need the stronger diff and axles... I had to do this with my conversion. If your car has ABS there is also a mod that you need to do with the speed sensors. You can ring me for more info if you need it (09)2722546 BTW: Welcome to the forum... that will be some beast once youve got it all sorted. woops this is correct, the ti axles wont bolt up to the e30 diff Quote Share this post Link to post Share on other sites
