DRYICE
How to install clear corners on e36?
Hi there, anyone got any links or instructions on how to install clear corners for a 2dr e36?All the companies selling them all say easy to install. How easy are they really?
Cheers
DRYICE
It is extremely easy .. it's a matter of undoing like 1 or 2 screws on each indicator and then it comes out ... and then you just slot the new one back in ..
Yep same thing ... if you go take a look at your car .. and look just on top the indicators from inside the hood you will see a screw hole ... it's a matter of putting a phillips head screw driver down there unscrewing it .. and the indicators come out ..
Mine just has a tab which you pry open (gently) with a flathead screwdriver and the indicator just slides out
easy peasy, I've done it ten times this weekend cos my indicator keeps deciding to stop, prolly a dirty/loose connection.
