DRYICE 0 Report post Posted January 7, 2005 Hi there, anyone got any links or instructions on how to install clear corners for a 2dr e36?All the companies selling them all say easy to install. How easy are they really? Cheers DRYICE Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted January 7, 2005 It is extremely easy .. it's a matter of undoing like 1 or 2 screws on each indicator and then it comes out ... and then you just slot the new one back in .. Quote Share this post Link to post Share on other sites
DRYICE 0 Report post Posted January 7, 2005 Sorry i mean clear corners like these ones...Same sort of thing? Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted January 7, 2005 Yep same thing ... if you go take a look at your car .. and look just on top the indicators from inside the hood you will see a screw hole ... it's a matter of putting a phillips head screw driver down there unscrewing it .. and the indicators come out .. Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted January 7, 2005 Hey I can get yousome clears quite cheaply..... pm me if you're interested! Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted January 10, 2005 Just make sure you catch it as it falls out, otherwise, chipped paint. Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted January 11, 2005 (edited) experience in this sam? Edited January 11, 2005 by bmwsparkle Quote Share this post Link to post Share on other sites
Jimocles 0 Report post Posted January 30, 2005 Mine just has a tab which you pry open (gently) with a flathead screwdriver and the indicator just slides out easy peasy, I've done it ten times this weekend cos my indicator keeps deciding to stop, prolly a dirty/loose connection. Quote Share this post Link to post Share on other sites
