Guest FrantiC Report post Posted November 6, 2009 Looking to sell my 2.7 short block, has ETA crank rods and pistons. I bought it with 66,000kms . Drove it about 3-4,000kms and spent about 50km of it's life with a turbo. 10.2:1 CR flat top ETA pistons.. Brand new water pump and tensioner and timing belt. toothed crank wheel and mint crank sensor to run 1.3 motronic Thinking, $600? Also a fresh 885 head, Was rebuilt a couple months ago. Barely 50k's on it. New stem seals, valve guides, valve seats, rocker grind, head skimmed, crack and strength tested. Was sitting on a steel headgasket so the surface is still mint as. $500 Or... I can chuck in the 885 head, ETA 2.7 bottem end, intake and throttle body, Alternator and belt, pulleys, crank wheel and crank sensor, Sure I have a sump liying around somewhere too.. $1100 and its yours.. Offers welcome. No clutch / flywheel assembly available. Can possibly do a deal with turbo bits too if interested. Though I have already taken it apart as I was going back to N/A but have other plans in mind. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 6, 2009 Why are you selling ?? I thought you had it all worked out and susted Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted November 6, 2009 Just 'coz. Also a M20 Facelift radiator, No leaks or anything $60. Radiator expansion bottle (Passenger side) $20. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted November 6, 2009 Gotta be a rota. That's my guess. Any sign of damage to the pistons from the time as a turbo? Quote Share this post Link to post Share on other sites
mark247 41 Report post Posted November 6, 2009 (edited) I know what it is. tehehehehe. By the way, empty your inbox so I can pm you bei. Edited November 6, 2009 by Mark247 Quote Share this post Link to post Share on other sites
l0w320 0 Report post Posted November 6, 2009 id be soo keen on the whole setup (without the turbo) just need to save up a bit of money first Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted November 6, 2009 Gotta be a rota. That's my guess. Any sign of damage to the pistons from the time as a turbo? Nah, they look sweet. Looks as they do when you pull of a standard motor apart. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted November 6, 2009 I know what it is. tehehehehe. By the way, empty your inbox so I can pm you bei. shhhhhhhhhhhh done it ow Quote Share this post Link to post Share on other sites
