Toomuch 0 Report post Posted January 10, 2005 hi,How hard is it to bleed a clutch on a 1983 320i,can you do it yourself,Cheers Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted January 10, 2005 You need two people to do it, one under the car at the slave cylinder end and one at the clutch pedal / resovoir end, and no it's not that difficult. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted January 10, 2005 Just get a tube on the slave bleed valve.. get someone to pump pump pump the clutch 3 times-ish.. hold the pedal down.. undo the bleed valve - fluid comes out, do up the bleed valve and repeat untill no bubbles in the tube. Make sure you keep topping up the fluid. Quote Share this post Link to post Share on other sites
Toomuch 0 Report post Posted January 10, 2005 sweet az thanks Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 10, 2005 and keep going until all the old fluid is gone ussually the new fluid is noticeably cleaner. Quote Share this post Link to post Share on other sites
