iSO 0 Report post Posted November 21, 2009 Hey im looking to do a manual conversion. im going to do it myself because im on a limited budget. i am mechanicaly minded and took auto mech at school for like 3 years so i do know my way around. but ive never done a conversion before and i worked on jappas at school so ive never touched a bmw before. can anyone help? like would any bmw manual fit? how the clutch gets fitted, if i need to change the flywheel etc... thanks guys. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 22, 2009 (edited) For an 87 E30 320i you require a getrag 240 box ( or bigger 260 will fit) - to fit an M20 engine. You also require everything else in the conversion - pedal box (brake pedal + manual bolt at least - to convert auto pedal box), clutch master & slave cylinders, fluid line, box, flywheel, clutch, pressure plate, release bearing, spigot bearing, manual d/shaft or at least manual front section to convert yours. A straight forward job but with respect - if you are asking on clutch & flywheel - I recommend you get help from someone who knows. Edit to description Edited November 22, 2009 by hotwire Quote Share this post Link to post Share on other sites
iSO 0 Report post Posted November 26, 2009 For an 87 E30 320i you require a getrag 240 box ( or bigger 260 will fit) - to fit an M20 engine. You also require everything else in the conversion - pedal box (brake pedal + manual bolt at least - to convert auto pedal box), clutch master & slave cylinders, fluid line, box, flywheel, clutch, pressure plate, release bearing, spigot bearing, manual d/shaft or at least manual front section to convert yours. A straight forward job but with respect - if you are asking on clutch & flywheel - I recommend you get help from someone who knows. Edit to description would it be easier to take the whole engine out or just take out the back mounts? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 26, 2009 (edited) I suggest you use the "search" function on the forum... this has been covered so many friggen times its not funny and boring Edited November 26, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted November 26, 2009 I've done it before and can give you a hand / guidance if you want.. Or could do it for you for a couple box's or something.. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 26, 2009 I've done it before and can give you a hand / guidance if you want.. Or could do it for you for a couple box's or something.. Can do it or a couple of boxes (i'm assumming booze) - shite you're cheap labour! Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted November 26, 2009 (edited) Actually yeah I'll re-think that offer lol.. But hit me up and I can do the whole swap for cheap.. Just supply all the parts and I can have it done in a day. Edited November 26, 2009 by e30ftw Quote Share this post Link to post Share on other sites
