SiK-E34 0 Report post Posted December 1, 2009 found a working 3.5ltr engine for sale just curious which gearbox will bolt upto it?? cheers Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted December 1, 2009 Needs to be a M30 box, yours won't work. The box alone would eat up your budget, I'd stick to a straight swap. Quote Share this post Link to post Share on other sites
3series 0 Report post Posted December 1, 2009 If the whole thing is going to cost more than $2000 or 2500 incl parts and labour etc. you should probably look into the option of buying another car as there is plenty out there around htat price. Quote Share this post Link to post Share on other sites
SiK-E34 0 Report post Posted December 1, 2009 If the whole thing is going to cost more than $2000 or 2500 incl parts and labour etc. you should probably look into the option of buying another car as there is plenty out there around htat price. I have found a motor and gearbox delivered to my door for 1400 in running cond, str8 out of an E34..... Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted December 1, 2009 I have found a motor and gearbox delivered to my door for 1400 in running cond, str8 out of an E34.....Complete with loom and any different parts? Not too sure if the mounts would be the same. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted December 1, 2009 you need the lot . engine and trans with all the loom from both those . all the ecu's , drivehshaft , diff and subframe etc , exhaust . if you can pick up a 535ia thats has body damage or rust then its worth it other wise you will get stuck with something that doesn't work and having to keep buying bits etc but i guess thats good for our business Quote Share this post Link to post Share on other sites
