Mike 1 Report post Posted December 6, 2009 (edited) Got around to putting the amp and sub into the E39 today. Power was easy enough with the battery being in the boot but I'm not sure that the signal input is ok. I simply cut into the rear speaker inputs from the H/U to factory amp (I left the factory stuff all working) and wired some RCA plugs onto the end and ran it to the amp. It all sounds and works fine but I'd just like to double check that I'm not likely to damage any of the factory stuff? I was thinking about upgrading the rest of the factory stuff but I might just chuck some new mids and tweeters in the fronts and leave it at that. Not such a fan of that box either, I'd like to pull the sat nav gear out the way and mount something off the roof of the boot. Lastly - what are the 2 modules on either side of the sub-box? Cheers Edited December 6, 2009 by Mike Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 6, 2009 Got around to putting the amp and sub into the E39 today. Power was easy enough with the battery being in the boot but I'm not sure that the signal input is ok. I simply cut into the rear speaker inputs from the H/U to factory amp (I left the factory stuff all working) and wired some RCA plugs onto the end and ran it to the amp. It all sounds and works fine but I'd just like to double check that I'm not likely to damage any of the factory stuff? I was thinking about upgrading the rest of the factory stuff but I might just chuck some new mids and tweeters in the fronts and leave it at that. Not such a fan of that box either, I'd like to pull the sat nav gear out the way and mount something off the roof of the boot. Lastly - what are the 2 modules on either side of the sub-box? Cheers Mike, Can't see any problem with hookup of amp as you are using RCA's so is low level. Don't like those bloody scotch lock connections though Don't you like front speaker setup? I find it ok. Will be a bit of rearranging as the front mid & bass speakers mount into a specific enclosure. Sat nav positioning in Jap car is a pain in the a... Gets in the way for boot access. Having said that - mine is still there. All other market cars - they are located in L/H rear by the amp etc. Haven't got round to it yet but I was thinking of fitting a DIN mount DVD player in the L/H corner in a cradle that the Euro nav normally mounts into. One day! Two modules either side in seat back: L/H side - Radio tuner (that crappy Jap one) R/H side - video module (TV tuner) Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted December 6, 2009 Ditch those blue connectors. They often fail. Good luck doing anything to the front. BMW has made it particularly difficult to improve Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted December 21, 2009 I recently installed an amp and sub in to my E39. I ended up using a Line output converter ($20 from Jaycar) by simply tapping in to the left rear speaker output from the factory amp with a female to female bullet connector. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted December 21, 2009 SECURE YOUR SUB!!!! NOW!!! you don't have much cable length there your going to rip something out of something on the first decent corner you take (i.e. 30kph driving like granny)... Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted December 21, 2009 +1 Done that... it's annoying. Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted December 21, 2009 Dont worry it is. Hmmm, didnt know those connectors were that dodgy. Whats the preference over cutting and crimping, or soldering and heat shrinking for tapping into existing wire? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 21, 2009 Dont worry it is. Hmmm, didnt know those connectors were that dodgy. Whats the preference over cutting and crimping, or soldering and heat shrinking for tapping into existing wire? Yep, splice into wire, solder the splice & tape. Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted December 21, 2009 To double check your install, go to the bavariansoundworks website, plug in you car details and search for subwoofer or speaker upgrades. Then go to the "Install info" tab there's step by step instructions including which wires to tap into. Quote Share this post Link to post Share on other sites
