Markq 0 Report post Posted January 18, 2005 I have a E30 320i. It has developed a ticking noise from the engine/engine bay that speeds up when the revs increase. Any idea what this may be? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted January 18, 2005 (edited) It'll be either injectors or valve clearances EDIT: my last car, an izuzu, had noisey tapets but I don't think that's a bmw prob??? Edited January 18, 2005 by ///Carl Quote Share this post Link to post Share on other sites
Markq 0 Report post Posted January 18, 2005 Easy fix or hard fix? I have also been told on a Trademe it could be seals in the hydralic lifters drying out. recommended Pro-Ma MBL8? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted January 18, 2005 My car has a ticking noise albeit subtle...needs a good tune up I wreckon, it's been serviced up until recently by Shelleys BMW here in welly but that does nothing in the way of actual mechanical maintenance. I've been told by Ian (hartage) to get my valve clearnaces done so I guess he knows the cost??? Quote Share this post Link to post Share on other sites
Markq 0 Report post Posted January 18, 2005 Yeah, the ticking is subtle on mine too. Who's Ian? Quote Share this post Link to post Share on other sites
Guest WAGON Report post Posted January 18, 2005 i would like to find out also as my touring has devloped the same thing Quote Share this post Link to post Share on other sites
petone 0 Report post Posted January 18, 2005 (edited) You can do the valve adjust yourself easy enough. You need torque wrench, valve cover gasket, feeler gauges plus a few other tools which i'm not exactly sure on, just stuff like a stiff wire to move adjusters and a 10mm spanner etc. There are plenty of write ups on different tech sites, search around for them. Other than time the only cost is valve cover gasket., which is $17 for M10 i think. a gasket for you M20 shouldn't be too much more. Don't expect the noise to go away completly though, its normal for all e30 to have a quiet ticking noise. Edited January 18, 2005 by petone Quote Share this post Link to post Share on other sites
Guest WAGON Report post Posted January 18, 2005 if its normal i wont worry Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted January 18, 2005 Just learn to live with it. It seems that most of the 6 cylinder E30's develop this ticking noise. Mine has had it for 5 years, I just ignore it, there is nothing wrong with my car, and it is not causing any harm to it. Cheers Quote Share this post Link to post Share on other sites
Vent 0 Report post Posted January 18, 2005 Mine does the same thing, 6 cylinder E30.. Altho Im thinking mine is more of an exhaust leak... Also, i get a ticking from behind the dash, which i put down to a noisy speedo cable? it goes away after driving for 5 mins or so.. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted January 18, 2005 It is the tappets/lifters. As petone has said, you can adjust them, but you prob won't get the noise to go away completely esp as the cam will prob be slightly worn and adding to the prob. Almost all m20's I've heard have it to some degree. hey petone - didn't think you could adjust the tappets on a M10? Quote Share this post Link to post Share on other sites
Vent 0 Report post Posted January 18, 2005 While we're on the subject of weird noises... I also get a very strange "thump" from the boot/rear of car. Happens only when i turn RIGHT hand corners.. and turning LEFT hand corners seems to RESET it... so if i turn left, no noise.. but next right turn, i get the thump. If i turn another right corner, without turning left, no thump. i have done a very exhaustive search of my boot, made sure that theres nothing in there thats rolling around. Made sure my jack, and other tools are secure. Battery is secure. Subs are secure enough (heavy, and carpetted, so shouldnt move) So im at a loss.. only other thing im considering it might be, is something mechanical under the car, such as axles, possibly diff related? Very strange.. I should take my subs out of the car and see if it still does it. Then remove all tools, see if it still does it.. so on until i get rid of the noise.... bloody frustrating. Quote Share this post Link to post Share on other sites
petone 0 Report post Posted January 18, 2005 Yeah M10 has adjustable valves and does the little ticking as well. Its normally not doing any harm but if it gets bad you could be losing power or putting extra strain on the rocker arms and valve gear. Vent, you noise could be the exhaust nocking against something, my one did the same thing for a bit. From the noise it was making i didn't think thats what it would be but sure enough it was. Quote Share this post Link to post Share on other sites
318is 0 Report post Posted January 18, 2005 While we're on the subject of weird noises... I also get a very strange "thump" from the boot/rear of car. Happens only when i turn RIGHT hand corners.. and turning LEFT hand corners seems to RESET it... so if i turn left, no noise.. but next right turn, i get the thump. If i turn another right corner, without turning left, no thump. i have done a very exhaustive search of my boot, made sure that theres nothing in there thats rolling around. Made sure my jack, and other tools are secure. Battery is secure. Subs are secure enough (heavy, and carpetted, so shouldnt move) So im at a loss.. only other thing im considering it might be, is something mechanical under the car, such as axles, possibly diff related? Very strange.. I should take my subs out of the car and see if it still does it. Then remove all tools, see if it still does it.. so on until i get rid of the noise.... bloody frustrating. semi floating r/h diff / axle ??? Quote Share this post Link to post Share on other sites
Markq 0 Report post Posted January 19, 2005 ARE YOU SURE YOU DON'T HAVE ANYONE STASHED AWAY IN THE BOOT!! Quote Share this post Link to post Share on other sites
Vent 0 Report post Posted January 19, 2005 ARE YOU SURE YOU DON'T HAVE ANYONE STASHED AWAY IN THE BOOT!! No, i checked for stashed people. Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted January 19, 2005 Mine does the same thing, 6 cylinder E30.. Altho Im thinking mine is more of an exhaust leak... Also, i get a ticking from behind the dash, which i put down to a noisy speedo cable? it goes away after driving for 5 mins or so.. You don't have a speedo cable so the noise isn't coming from there. My guess would be rust under the battery or the rubber grommet around the ECU wiring has fallen out. Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted January 19, 2005 Easy fix or hard fix? I have also been told on a Trademe it could be seals in the hydralic lifters drying out. recommended Pro-Ma MBL8? 320's don't have hydralic lifters. Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted January 19, 2005 While we're on the subject of weird noises... I also get a very strange "thump" from the boot/rear of car. Happens only when i turn RIGHT hand corners.. and turning LEFT hand corners seems to RESET it... so if i turn left, no noise.. but next right turn, i get the thump. If i turn another right corner, without turning left, no thump. i have done a very exhaustive search of my boot, made sure that theres nothing in there thats rolling around. Made sure my jack, and other tools are secure. Battery is secure. Subs are secure enough (heavy, and carpetted, so shouldnt move) So im at a loss.. only other thing im considering it might be, is something mechanical under the car, such as axles, possibly diff related? Very strange.. I should take my subs out of the car and see if it still does it. Then remove all tools, see if it still does it.. so on until i get rid of the noise.... bloody frustrating. Worn rear sway bar links or muffler hitting the body. Quote Share this post Link to post Share on other sites
petone 0 Report post Posted January 19, 2005 only a 320, chances are it wont have a sway bar. My bets on the muffler. Quote Share this post Link to post Share on other sites
