DFF53 1 Report post Posted December 8, 2009 Well someone was looking at my car's engine bay and whose itchy fingers decided to manually move the throttle assy to rev the car. Suddenlly the car's throttle seems to to be jammed open or something because it revs really hard even without any input from the pedal. I didnt really see how far up the range it will go, because having a 4hp22 i didnt really want it to rev too high while in park. I cleaned the throttle assy and tried taking it for a drive and it seems to drive itself. Please can someone tell me what is possibly gone wrong. I have removed the intake boot to see if the throttle flap is open while the car is parked but it isnt, it only happens when i start the car. Any input appreciated thanks. Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted December 8, 2009 Vacuum hose come loose anywhere? I have done that before.. Accidently pull of a vacuum hose and the car revs out really high. Or when I blew the brake booster hose off, that was making my car idle at 3.5k rpm Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted December 8, 2009 have you checked the idle control valve? if its stuck open then it will run lean and raise the rpm. abit of kero will free it up Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 8, 2009 they have pulled the cable plug thingy out of the cable holder gromet. Quote Share this post Link to post Share on other sites
DFF53 1 Report post Posted December 8, 2009 they have pulled the cable plug thingy out of the cable holder gromet.You maybe on to something when i had a look, some disintegrated plastic fell in my hand and the end of the cable came loose. But it is not the cable you pointed out but a secondary one which as far as i know is the cruise control actuator cable. Could this sill be the porblem. Cos it was running normal after i started it but as soon the dude pulled on the cable it started going crazy. Thanks for the help so far guys. I also sprayed Carb RClean on the sensors and throttle to clean them up. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 8, 2009 You maybe on to something when i had a look, some disintegrated plastic fell in my hand and the end of the cable came loose. But it is not the cable you pointed out but a secondary one which as far as i know is the cruise control actuator cable. Could this sill be the porblem. Cos it was running normal after i started it but as soon the dude pulled on the cable it started going crazy. Thanks for the help so far guys. I also sprayed Carb RClean on the sensors and throttle to clean them up. yes cruise cable been pulled away will do the same . Quote Share this post Link to post Share on other sites
DFF53 1 Report post Posted December 8, 2009 yes cruise cable been pulled away will do the same . How would you fix that, i tried pulling and pushing it while the the car was running but it did not seem to make a differance it was still reving steadily. Quote Share this post Link to post Share on other sites
DFF53 1 Report post Posted December 8, 2009 All fixed now, you were right, it was the throttle cable that was stuck it came loose and got stuck at the point where the yellow arrow indicates. thanks all for your help. Feel like a complete numpty. Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted December 9, 2009 its just the accelerator cable or cruise control. had that on my car as well. f**kin scared me when i started it and reved all the way up.. i got the plastic holder on the cable out of its socket and it caused the cable to pull on the throttle and rev. i popped it back in place and all was good again. Quote Share this post Link to post Share on other sites
