isis 16 Report post Posted December 12, 2009 Anyone knows which wire goes where? a mate handed me one. Also are there any exit holes to run it to the towbar? id rather not drill. Cheers Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted December 12, 2009 Anyone knows which wire goes where? a mate handed me one. Also are there any exit holes to run it to the towbar? id rather not drill. Cheers The wiring digram shows all wire colours: tail left grey/blue tail right grey/green reverse blue/white brake left green/yellow brake right green/blue blinker left blue/red blinker right blue/black ground is always brown Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted December 12, 2009 The wiring digram shows all wire colours: tail left grey/blue tail right grey/green reverse blue/white brake left green/yellow brake right green/blue blinker left blue/red blinker right blue/black ground is always brown should point out that you need to connect brake and tails on the connector plug to either the left or the right, not both. i made that mistake. probably the one that the high stop doesnt run off for the brake would be best put it probably doesnt matter Quote Share this post Link to post Share on other sites
isis 16 Report post Posted December 12, 2009 you do however need to run 1 wire from either the left or right signal light though, depending on which side plug u use.. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted December 13, 2009 you do however need to run 1 wire from either the left or right signal light though, depending on which side plug u use.. Are you sure? I thought on the European vehicles you could run both indicators from one side only? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted December 13, 2009 (edited) Are you sure? I thought on the European vehicles you could run both indicators from one side only? sarcasm? if not; the left and right signals are on seperate curcuits on every car. they HAVE to be. what you are probably confusing yourself with is the tails and brakes. on Japs the back the two tails are on the same curcuit and the two/three brake lights are on the same curcuit, while the front is the same. on euros however the left hand side is usually wired together (left headlight and left tail) and the right the same. think BMW (edit: E30) is independent in every corner though im not sure though i havent investigated that (edit: not sure if that helps on your car though) Edited December 13, 2009 by ethrty320 Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted December 31, 2009 Don't know if you've finished this or not, but when I put the towbar on my E28 I didn't have anywhere to mount a plug without drilling into the bumper or exterior body work. Instead I got some flat trailer cable (supercheap) and keep the plug nicely tucked away in the boot until needed, then it just hangs out the boot. Also means I can have more or less hanging out depending on the trailer. And it looks better too! Quote Share this post Link to post Share on other sites
