wolliver
e30 hub removal
ok so i am replacing my front left bearing, and just need to remove the old hub... is there any trick to taking this off? the hub is moving back a forwards about 5mm, but just wont come off.
any help would be appreciated,
thanks
thanks
have you got a puller?, its not on tight but it has to come off straight or it gets stuck
dont have a puller, can i use anything else?
ive used 2 pry bars before one on either side at the same time but be carefull not to bend the backing plate etc
got it all off finally, just wondering if i should put some grease on the axle and or just leave it?
just a little bit on the shaft wont hurt
