wolliver 1 Report post Posted December 12, 2009 ok so i am replacing my front left bearing, and just need to remove the old hub... is there any trick to taking this off? the hub is moving back a forwards about 5mm, but just wont come off. any help would be appreciated, thanks Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted December 12, 2009 ok so i am replacing my front left bearing, and just need to remove the old hub... is there any trick to taking this off? the hub is moving back a forwards about 5mm, but just wont come off. any help would be appreciated, thanks have you got a puller?, its not on tight but it has to come off straight or it gets stuck Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted December 12, 2009 dont have a puller, can i use anything else? Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted December 12, 2009 dont have a puller, can i use anything else?ive used 2 pry bars before one on either side at the same time but be carefull not to bend the backing plate etc Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted December 13, 2009 got it all off finally, just wondering if i should put some grease on the axle and or just leave it? Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted December 13, 2009 got it all off finally, just wondering if i should put some grease on the axle and or just leave it?just a little bit on the shaft wont hurt Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted December 13, 2009 thats what she said... na all done thanks for the help Quote Share this post Link to post Share on other sites
