APT 198 Report post Posted December 16, 2009 Recently my E30 (M20B25) has had some trouble starting. Ive checked the battery, leads, spark plugs. You can hear the car turning over but its hard to start at times, sometimes it takes me 3 times to start this is even after i drive it. My question is does this sound like a faulty fuel pump or distributor/rotor? ive changed the fuel filter just recently as well. Thanks Andrew Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 16, 2009 There are several things that need checking... like everything else I've tried to help you with.. unfortunately to help you it will cost $$$ . Someone on here might give you a list, but you will need the right tools and test equiptment to carry out these tests properly Quote Share this post Link to post Share on other sites
APT 198 Report post Posted December 16, 2009 There are several things that need checking... like everything else I've tried to help you with.. unfortunately to help you it will cost $$$ . Someone on here might give you a list, but you will need the right tools and test equiptment to carry out these tests properly Thanks Glenn i do realise that it will cost $$$. Still havent got back to you about those shocks lol. Quote Share this post Link to post Share on other sites
