khairul23 0 Report post Posted December 28, 2009 I have this intermittent problem. While driving, sometimes the ABS warning light shows on the dash. At exactly the same time, the speedometer needle drops to zero and doesn't function. Sometime later the ABS warning light goes away, and at the exact same time, the speedometer needle starts working again. The first time I noticed this happen, there was some weird loud noise when I pressed the brake. But the noise was only one-off. It does not recur even when the ABS warning light shows up again. Weeks before all these happen until now, there was some soft clinking noise when I press the brake, very subtle as compared to that one occasion above. Any ideas what could be wrong? Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted December 28, 2009 (edited) I have this intermittent problem. While driving, sometimes the ABS warning light shows on the dash. At exactly the same time, the speedometer needle drops to zero and doesn't function. Sometime later the ABS warning light goes away, and at the exact same time, the speedometer needle starts working again. The first time I noticed this happen, there was some weird loud noise when I pressed the brake. But the noise was only one-off. It does not recur even when the ABS warning light shows up again. Weeks before all these happen until now, there was some soft clinking noise when I press the brake, very subtle as compared to that one occasion above. Any ideas what could be wrong? Have a look at this, >>Clicky me<< , The Symptoms seem the same as yours Edited December 28, 2009 by M-Spec Quote Share this post Link to post Share on other sites
khairul23 0 Report post Posted December 28, 2009 Have a look at this, >>Clicky me<< , The Symptoms seem the same as yours Your link looks highly probable. I'll give it a try. Thanks. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 28, 2009 yes pretty common abs sensor failure . i a have some for pre 1999 models also the electronics in the abs pump can fail due to dry joints etc.the abs modules can be repaired Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted December 28, 2009 I have this intermittent problem. While driving, sometimes the ABS warning light shows on the dash. At exactly the same time, the speedometer needle drops to zero and doesn't function. Sometime later the ABS warning light goes away, and at the exact same time, the speedometer needle starts working again. The first time I noticed this happen, there was some weird loud noise when I pressed the brake. But the noise was only one-off. It does not recur even when the ABS warning light shows up again. Weeks before all these happen until now, there was some soft clinking noise when I press the brake, very subtle as compared to that one occasion above. Any ideas what could be wrong? Likely wheel speed sensor fault Without using a diagnostic tool to find out which sensor is faulty, you have to work blind Working blind means: Visually inspect all 4 wheel sensors for damage. Look carefully at the cable and the connectors Then replace the sensors one by one until you find the faulty unit You may not have a faulty speed sensor, the problem may be in the ABS control unit. If so, replace ABS control unit PS: using a BMW Diagnostic Scanner will locate and identify the problem very quickly. Quote Share this post Link to post Share on other sites
HELLBM 1687 Report post Posted December 28, 2009 We have replacement sensors etc. at the best prices. We can scan and isolate the problem easily with BMW GT1 diagnostics for those who are in the Auck. area. A very common problem. Quote Share this post Link to post Share on other sites
khairul23 0 Report post Posted December 29, 2009 Thanks guys. I've got a scanner that I could try use to find what the fault may be. I'll get in contact if a sensor needs replacing. Quote Share this post Link to post Share on other sites
Hamilton E39 530i 0 Report post Posted March 5, 2012 (edited) My 2000 520ia did this too. If it only does it once the car is warm it is most likely the ABS computer module in the engine bay. We did the fault code thing but it was a red-hearing. Changed an ABS sensor at the wheel and it made no difference. BM Warehouse were great and took the sensor back luckely for me. If the problem is related to the temp of the engine compartment it is the ABS comp. The original contacts crack and when the unit gets hot you get all sorts of ABS faults. I sent mine to an ABS workshop in Tauranga. They took it apart, replaced the aluminium contacts with copper ones and sent it back all fixed. I think it was around $260 You can still drive the car with the ABS comp off but you have no speed or ABS. Edited March 5, 2012 by Stephen O Quote Share this post Link to post Share on other sites
