Slavvy 0 Report post Posted December 29, 2009 Just a quick question. I recently bought an m30 with a manual gearbox and the factory original(!) clutch attached. I intend to replace the clutch with a new one and I want to get the flywheel skimmed flat just to play it safe. My question is whether I can do this as per a regular flywheel as it seems to be a dual mass one, the motor etc came out of an e34 535 and the flywheel is quite clearly multiple pieces put together. Would this affect getting it skimmed at all? I don't see it making any difference but I thought I'd ask haha. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 29, 2009 The flywheel needs to be checked first. There is a procedure. 75% of the time, even on later model cars the flywheel will need replacing. I can check it after the 5th for you Quote Share this post Link to post Share on other sites
Slavvy 0 Report post Posted December 29, 2009 The flywheel needs to be checked first. There is a procedure. 75% of the time, even on later model cars the flywheel will need replacing. I can check it after the 5th for you Sweet as, I'll try to get in around then. Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted December 29, 2009 Hi Max i just had a m30 clutch plate resurfaced with kevlar,full face,not puk style.Easier to drive round town. and pressure plate fingers 'retentioned' up to 2400lbs. will be a good upgrade for the SS upgrade and grip awesomelly with the increased torque. wont be going ahead with the plans i had in mind $600 cheers marty Quote Share this post Link to post Share on other sites
Slavvy 0 Report post Posted December 29, 2009 Hi Max i just had a m30 clutch plate resurfaced with kevlar,full face,not puk style.Easier to drive round town. and pressure plate fingers 'retentioned' up to 2400lbs. will be a good upgrade for the SS upgrade and grip awesomelly with the increased torque. wont be going ahead with the plans i had in mind $600 cheers marty I'll find out if I can get the same sort of thing for less through other channels, if not I'll be sure to hit you up Quote Share this post Link to post Share on other sites
