simke 0 Report post Posted December 30, 2009 Car wouldn't unlock, passenger or drivers side, could open the boot fine but it wouldn't unlock the doors as well. After lots of trying managed to unlock drivers door. Now windows and sunroof wont work, and locking is still stuffed - tried locking passenger door, didn't lock any other locks and can't unlock it again. Any ideas what this might be? Hopefully not too expensive to fix, especially since I don't intend to keep this car for long. Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted December 30, 2009 Replace the GM or RM module under the back seat, left. Have both. Quote Share this post Link to post Share on other sites
simke 0 Report post Posted December 30, 2009 How much? I did check the fuse that is in the box under rear seat (no. 47) appears to be fine. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted December 30, 2009 also check the fusable link that comes off the battery positive terminal , its wrapped in plastic wrap on the smaller power cable they break offten Quote Share this post Link to post Share on other sites
bmwwgn 14 Report post Posted March 18, 2010 Similar problem on my 94 530iA, but not quite so bad: Driver's door will not respond to remote central locking. Also will not lock when key locking via passenger's door or boot. However key locking driver's door will lock everything. Seems like a lack of electrons to the driver's door locking actuator - any similar experiences out there, or a simple fix? Note: car had a Mongoose alarm installed which has been deactivated/removed. Cheers. Quote Share this post Link to post Share on other sites
