reaper47
slight miss above idol
What could/ would be the likely cause of a slight miss just above idol?
Car is a z3 m coupe. No miss above 3000rpm.
Could it be under-performing injectors?
any ideas would be appreciated.
Nik
Edited by reaper47
failed ignition coil .
oil down the spark plug holes .
broken fan blade.
get it scanned maybe
broken fan blade.
Has been scanned. nothing showing. :unsure:
hhhmmm maybe a vaccum leak on one of the little intake hoses etc .
will make it run lean at low rpm .
Who scanned it? and did they check live data & cylinder balance ? Alot of faults in BMW's don't throw fault codes even when there is a problem. You need to use the scan tool properly and have an understanding of the available data given to you by the tool.
