Andrew 30 Report post Posted January 9, 2010 Pics and stuff on tardme http://www.trademe.co.nz/Browse/Listing.aspx?id=264701190 EDIT: Worth mentioning it used the in gearbox sensors. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3009 Report post Posted January 10, 2010 Excuse my ignorance, but is the ECU 'programmable' , ie can you change the maps on it (via laptop or whatever), or does it just run the maps already set up on it? If it is programmable does it come with the software? Cheers, JTP Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 10, 2010 Software is freely available: www.linkecu.com Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted January 11, 2010 (edited) Excuse my ignorance, but is the ECU 'programmable' , ie can you change the maps on it (via laptop or whatever), or does it just run the maps already set up on it? If it is programmable does it come with the software? Cheers, JTP Hey Jon It fully replaces the stock computer and sensors. So it runs a MAP sensor (no AFM). You can change the maps easily using the software Cam posted. It would probably run most 6 cylinder e30s with the tune it has (to get it started and moving around). Edited January 11, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
