Brad-325i 2 Report post Posted January 10, 2010 Hey now im about to attempt to take the cd player that was origionaly in my car out and chuck in an amp and sub. now before i disconnect the battery terminals is there anything i should know?? Anything i should do b4hand? Cheers, Brad Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted January 10, 2010 Nup, just disconnect neg terminal on battery Quote Share this post Link to post Share on other sites
Brad-325i 2 Report post Posted January 10, 2010 Nup, just disconnect neg terminal on battery When i do that my alarm goes off but sounds like its bout to die haha and i lost the key to turn the siren off so shuld i jst let it go till it dies? if i connect the neg terminal again the alarm works perfectly fine again. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2142 Report post Posted January 10, 2010 When i do that my alarm goes off but sounds like its bout to die haha and i lost the key to turn the siren off so shuld i jst let it go till it dies? if i connect the neg terminal again the alarm works perfectly fine again. Its probably got a backup battery in it for when the car is locked for extended periods of time. its often a 9V battery. see if you can see an access panel for it Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 10, 2010 Just put a rag inside the siren to quieten it down and let the back up battery go flat after you disconnect the main battery... it wont hurt it Quote Share this post Link to post Share on other sites
Brad-325i 2 Report post Posted January 10, 2010 Just put a rag inside the siren to quieten it down and let the back up battery go flat after you disconnect the main battery... it wont hurt it how long will it take to go flat? i have neighbours that complain about every little sound i make. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 10, 2010 Not long .. a few minutes Quote Share this post Link to post Share on other sites
summerscheifer 0 Report post Posted January 26, 2011 i know its was a year old one but im just having the problem on my bmw battery when i switch in the battery one,it make quick tick sound from relay in motor,but when i switch to battery two or both it will start right up,is the relay bad?or i need to check something else?or should i have a battery switch for that?please give me some tips. thanks. Quote Share this post Link to post Share on other sites
