_ethrty-Andy_
E32 Brake Master
Must be known good condition, no speculation. From/to suit 750iL. Jeff Gray BMW think 740iL, 735i and 730iL use the same master, so that will be fine if it in fact the same. Thanks
Which one did you buy ?? bore size ? and outlets ?..... does your car have ABS ??
