Davee 0 Report post Posted January 29, 2010 Hello, How hard is it to replace this sensor. Do I end to know hoe to reset any codes and any idea of the cost of the sensor, Thanks Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted January 29, 2010 From memory, mine was about $270 installed at BM Workshop (incl. about 30 mins or so labour, and a car wash) - so a relatively simple install if you know what you are doing and have the tools. And yes, they did have to reset the fault code on my 330. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 29, 2010 Hello, How hard is it to replace this sensor. Do I end to know hoe to reset any codes and any idea of the cost of the sensor, Thanks The camshaft sensors have gone up in price quite considerably Dave. If I can have your chassis # I can give you a price with member discount... and yes the fault codes need to be erased and adaptions nee to be cleared, you can only do this with a good scanner. If you are in Auckland we can do this for you.. ring me @ Botany Motor Worx (09) 2722546 Quote Share this post Link to post Share on other sites
Davee 0 Report post Posted January 29, 2010 The camshaft sensors have gone up in price quite considerably Dave. If I can have your chassis # I can give you a price with member discount... and yes the fault codes need to be erased and adaptions nee to be cleared, you can only do this with a good scanner. If you are in Auckland we can do this for you.. ring me @ Botany Motor Worx (09) 2722546 thanks - sorry I,m in Christchurch. Keen to get a price for the part if you can.My chassis # is wbafa520xolm44449. Thanks Dave Quote Share this post Link to post Share on other sites
HELLBM 1648 Report post Posted January 29, 2010 $100 including postage. regards Ray 0212435526 Quote Share this post Link to post Share on other sites
Davee 0 Report post Posted January 30, 2010 $100 including postage. regards Ray 0212435526 Your offer is very tempting. Is this part new or second hand? Still need to check out what needs to be done to replace this sensor first, as I will need to be able to access the error codes to reset. Dave Quote Share this post Link to post Share on other sites
HELLBM 1648 Report post Posted January 30, 2010 Your offer is very tempting. Is this part new or second hand? Still need to check out what needs to be done to replace this sensor first, as I will need to be able to access the error codes to reset. Dave Secondhand but scaned up ok. Not to difficult to replace and easy to reset. Don`t let them tell you otherwise. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 30, 2010 thanks - sorry I,m in Christchurch. Keen to get a price for the part if you can.My chassis # is wbafa520xolm44449. Thanks Dave Will do Tuesday morning. As Ray said...easy to fit, but you will have to get the fault code & adaptions cleared with an appropriate scanner. Was the fault checked with a reliable scanner ? Quote Share this post Link to post Share on other sites
Davee 0 Report post Posted January 31, 2010 Will do Tuesday morning. As Ray said...easy to fit, but you will have to get the fault code & adaptions cleared with an appropriate scanner. Was the fault checked with a reliable scanner ? Great thanks. Was checked at BMW - I'm keen to repalce myself once I undersand the new sensor cost. Can you recoomend a good Scanner . I was thinking of getting a Actron CP9175? Many Thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 31, 2010 Great thanks. Was checked at BMW - I'm keen to repalce myself once I undersand the new sensor cost. Can you recoomend a good Scanner . I was thinking of getting a Actron CP9175? Many Thanks Sometimes generic scanners wont cut the mustard. You must be careful... post a link Quote Share this post Link to post Share on other sites
Davee 0 Report post Posted February 1, 2010 Sometimes generic scanners wont cut the mustard. You must be careful... post a link Hi Glenn, Did you manage to get a price for the Sensor Plus 0-ring? Many Thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 1, 2010 Ooops....been real busy Sensor Retail $337.69 + Gst I can do for $287.15 + Gst "O" ring $ 04.17 $ 3.75 + Freight to you Quote Share this post Link to post Share on other sites
Davee 0 Report post Posted February 5, 2010 Ooops....been real busy Sensor Retail $337.69 + Gst I can do for $287.15 + Gst "O" ring $ 04.17 $ 3.75 + Freight to you Thanks Glenn and Ray for your assistance. Given I'm in Christchurch, I needed to buy a scanner from the US to clear the codes I have done this and ordered the part at the same time. Pity your workshop is not in Christchurch Thanks again for your help Dave Quote Share this post Link to post Share on other sites
Davee 0 Report post Posted February 21, 2010 The camshaft sensors have gone up in price quite considerably Dave. If I can have your chassis # I can give you a price with member discount... and yes the fault codes need to be erased and adaptions nee to be cleared, you can only do this with a good scanner. If you are in Auckland we can do this for you.. ring me @ Botany Motor Worx (09) 2722546 Hi Glenn, Can you please advise what you mean by having to clear the adaptions. I replaced the Exhaust cam sensor like the deal said needed to be done. Tried to clear the code but when I use the Peake research code read I get a E10 or E11 which are the O2 sensors. any idea's Quote Share this post Link to post Share on other sites
Davee 0 Report post Posted February 21, 2010 Hi Glenn, Can you please advise what you mean by having to clear the adaptions. I replaced the Exhaust cam sensor like the deal said needed to be done. Tried to clear the code but when I use the Peake research code read I get a E10 or E11 which are the O2 sensors. any idea's Stupid me, E10 & E11 are error codes for the peak to indicate that has a problem with the connection to the onboard computer. Once I turned the key in the car to the second point the reader reset the service light. All fixed. Pays to reread instructions sometimes Quote Share this post Link to post Share on other sites
