APT 205 Report post Posted February 20, 2010 Hey guys I have removed and re installed front struts before but for some reason this time when installing the nut that attaches the tie rod it does not want to freely spin the whole way down it gets a couple of rotations then just tightens and spins the whole tie rod bolt around, and just gets stuck and spins the whole tie rod bolt. I am using the exact same nut i took off im using a 17mm socket and i used a tie rod end tool to break the tie rod bolt from the strut. Do i have to replace the tie rod end ? Sorry its abit hard to explain THANKS !! Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted February 20, 2010 Put a jack under the tie rod and then do it up. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted February 20, 2010 Does the bolt on the tie rod end that is spinning have a allen key fitting in the top of it? I use a ratchet spanner (or a ring spanner is fine) have it sitting on the nut, and while I am doing it up I have a allen key in the top bolt to stop the bolt spinning and just the nut turns. If that fails, vice grips are your friend will just mean you will need new tie rods next time probably Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted February 20, 2010 usually on the top of the bolt there is a hex or allen key hole. holds the bolt while you spin the nut. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted February 20, 2010 Isn't that what I just said???? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 20, 2010 Put a jack under the tie rod and then do it up. +1, just load up the ball joint from underneath with a jack and it'll do up straight away. Quote Share this post Link to post Share on other sites
APT 205 Report post Posted February 20, 2010 Does the bolt on the tie rod end that is spinning have a allen key fitting in the top of it? I use a ratchet spanner (or a ring spanner is fine) have it sitting on the nut, and while I am doing it up I have a allen key in the top bolt to stop the bolt spinning and just the nut turns. If that fails, vice grips are your friend will just mean you will need new tie rods next time probably There is no allen key on top of the bolt, but i will try the jack technique hopefully this can fix it. Thanks guys Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted February 20, 2010 The bolt is tapered - hence why the jack trick works, and why they are such a bitch to get off. Quote Share this post Link to post Share on other sites
APT 205 Report post Posted February 21, 2010 Havent given it a go yet but the jack trick seems like it will work, thank god Bimmersport is back online Quote Share this post Link to post Share on other sites
