Eddie 66 Report post Posted February 24, 2010 What mods do I need to make to rear toe adjustable on my e30/e36 compact rear Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted February 24, 2010 You can do it with eccentric rear trailing arm bushes, or weld on tabs on the cross member from Irelands or the like. Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted February 24, 2010 There are kits around that when fitted you can adjust toe camber and castor but you will have to reach deep into your pockets. Kits have new trailing arms etc which are adjustable. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 24, 2010 The kits arent expensive... paying someone to do it is, if you cant do it yourself. I'll be doing the Ti this winter and I'll do a project thread about it. $500 should cover the camber/toe kit, subframe & control arm bushes with sway bar links and bushes. Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted February 25, 2010 The kits arent expensive... paying someone to do it is, if you cant do it yourself. I'll be doing the Ti this winter and I'll do a project thread about it. $500 should cover the camber/toe kit, subframe & control arm bushes with sway bar links and bushes.Looking forward to this project. Is on my list as well but will do when I lower. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted February 25, 2010 http://www.e30tech.com/forum/showthread.php?t=80410 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted February 28, 2010 Thanks guys Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted February 28, 2010 Here is a kit http://store.bimmerworld.com/shared/StoreF...et=products.asp Quote Share this post Link to post Share on other sites
