Eddie
rear toe ajustment
You can do it with eccentric rear trailing arm bushes, or weld on tabs on the cross member from Irelands or the like.
There are kits around that when fitted you can adjust toe camber and castor but you will have to reach deep into your pockets. Kits have new trailing arms etc which are adjustable.
The kits arent expensive... paying someone to do it is, if you cant do it yourself. I'll be doing the Ti this winter and I'll do a project thread about it. $500 should cover the camber/toe kit, subframe & control arm bushes with sway bar links and bushes.
Looking forward to this project.
Is on my list as well but will do when I lower.
